When building a modified BSP based off of the torizon-core-docker image, the final license check of the rootfs build fails a lot, with errors like
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_func_python() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:license_create_manifest(d)
0003:
File: '/home/beb/npu-test/bsp-synchron/build/conf/../../layers/openembedded-core/meta/classes/license_image.bbclass', lineno: 37, function: license_create_manifest
0033: pkg_dic[pkg_name]["LICENSE"] = pkg_dic[pkg_name][pkg_lic_name]
0034:
0035: rootfs_license_manifest = os.path.join(d.getVar('LICENSE_DIRECTORY'),
0036: d.getVar('IMAGE_NAME'), 'license.manifest')
*** 0037: write_license_files(d, rootfs_license_manifest, pkg_dic, rootfs=True)
0038:}
0039:
0040:def write_license_files(d, license_manifest, pkg_dic, rootfs=True):
0041: import re
File: '/home/beb/npu-test/bsp-synchron/build/conf/../../layers/openembedded-core/meta/classes/license_image.bbclass', lineno: 127, function: write_license_files
0123:
0124: pkg_manifest_licenses = [canonical_license(d, lic) \
0125: for lic in pkg_dic[pkg]["LICENSES"]]
0126:
*** 0127: licenses = os.listdir(pkg_license_dir)
0128: for lic in licenses:
0129: pkg_license = os.path.join(pkg_license_dir, lic)
0130: pkg_rootfs_license = os.path.join(pkg_rootfs_license_dir, lic)
0131:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/beb/npu-test/bsp-synchron/build/deploy/licenses/cryptsetup'
Curiously, these failures are all from packages in openembedded-core (like cryptsetup, bridge-utils, cpufrequtils), packages whose recipes and licenses had worked before and presumably have been tested by many others.
It seems like I have an issue with the license_image.bbclass that generates and populates the license directory. I’ve tried wiping that directory to get bitbake to repopulate it, as well as manually adding a few directories to the license directory (in case it was only a few for some reason), but it would seem the issue is systemic.
Do you have any advice for dealing with such an issue?
I suggest cleaning package by package, another alternative is cleaning your environment (deleting tmp folder as an example), but it will take more time since you will need to rebuild every package from the beginning.
I am in the process of building after cleaning the environment (I tried package by package but it seemed the issue was affecting so many packages I didn’t want to do all that manually)
I will update this thread when the build succeeds or fails
I cleaned the environment entirely (deleting tmp, deploy, sstate-cache) and rebuilt the image, and got an acl license issue again:
ERROR: torizon-core-docker-1.0-r0 do_rootfs: Error executing a python function in exec_func_python() autogenerated:
0001:
0003:
0034:
0038:}
0039:
0041: import re
0123:
0126:
0131:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/beb/npu-test/bsp-synchron/build/deploy/licenses/acl'
Similarly to before i cleaned everything, cleaning and rebuilding acl results in a different license error (in this case aktualizer-docker-compose-sec), and I suspect rebuilding that will also result in another license error.
Have you seen any similar issues with perhaps the license_image.bbclass that creates the license directories? Is there a way to (at least temporarily) disable the license checking in the local.conf or something?
That’s strange, can you please create a new oe-core folder and start the build from the beginning on this new directory? I expected this to solve the issue.
Yes, I have faced this issue before and to solve this I cleaned package by package.
