Libsolve-native testsolv fails to link
Building the console-tdx-image from a clean slate with this command:
bitbake -k console-tdx-image
fails with 1 error, trying to link testsolv, with these errors:
../ext/libsolvext.so.0: undefined reference to `db_create_rpmdb'
../ext/libsolvext.so.0: undefined reference to `db_env_create_rpmdb'
I’m trying to build LinuxImageV2.8 for an Apalis-T30 setup.
Hi
I guess you are hit by what this patch solves. Unfortunately it was not pulled into openembedded-core layer.
My solution was then to uninstall the build host’s ‘rpm-devel’ package. Alternatively write a bbappend which applies the patch.
Max
The patch worked, although I had to apply it manually. For some reason, I couldn’t get “git am” to apply it. Oh well, I got it done.
