Below are the patches to board-colibri_t30.c that we are making for our product.
I see no complaints from Yocto about applying the patches, but maybe I am looking in the wrong place (the amount of information from yocto builds is enourmous). Would Yocto indeed report an error or just a warning if it failed to patch board file? If there was a warning, where I would I find that in the Yocto logs.
I am always having the problem that Yocto is not reporting enough information or reports WAY too much.
diff --git a/arch/arm/mach-tegra/board-colibri_t30.c b/arch/arm/mach-tegra/board-colibri_t30.c
index e6632db39c6a..bf022d082dec 100644
--- a/arch/arm/mach-tegra/board-colibri_t30.c
+++ b/arch/arm/mach-tegra/board-colibri_t30.c
@@ -566,7 +566,7 @@ static struct gpio colibri_t30_gpios[] = {
//conflicts with volume down key
{TEGRA_GPIO_PCC6, GPIOF_IN, "SODIMM pin 24"},
//conflicts with volume up key
- {TEGRA_GPIO_PDD7, GPIOF_IN, "SODIMM pin 22"},
+ /* {TEGRA_GPIO_PDD7, GPIOF_IN, "SODIMM pin 22"}, */
#endif
#ifndef COLIBRI_T30_VI
{TEGRA_GPIO_PDD5, GPIOF_IN, "SODIMM pin 69"},
2.30.2
index 8deda7ce51db..e6632db39c6a 100644
@@ -519,7 +519,7 @@ static struct gpio colibri_t30_gpios[] = {
#endif
#ifndef CONFIG_KEYBOARD_GPIO
//conflicts with back key
- {TEGRA_GPIO_PT5, GPIOF_IN, "SOD-133, Iris X16-14"},
+ /* {TEGRA_GPIO_PT5, GPIOF_IN, "SOD-133, Iris X16-14"}, */
//conflicts with home key
{TEGRA_GPIO_PT6, GPIOF_IN, "SODIMM pin 127"},
//conflicts with power key (WAKE1)
@@ -794,8 +794,8 @@ static struct gpio_keys_button colibri_t30_keys[] = {
GPIO_KEY(KEY_FIND, PCC2, 1, 0), /* SODIMM pin 77 */
#endif
GPIO_KEY(KEY_HOME, PT6, 1, 0), /* SODIMM pin 127 */
- GPIO_KEY(KEY_BACK, PT5, 1, 0), /* SODIMM pin 133,
- Iris X16-14 */
+ /* GPIO_KEY(KEY_BACK, PT5, 1, 0), /\* SODIMM pin 133, */
+ /* Iris X16-14 *\/ */
GPIO_KEY(KEY_VOLUMEUP, PDD7, 1, 0), /* SODIMM pin 22 */
GPIO_KEY(KEY_VOLUMEDOWN, PCC6, 1, 0), /* SODIMM pin 24 */
GPIO_KEY(KEY_POWER, PV1, 0, 1), /* SODIMM pin 45,
From e76d25fff2b3bce923439538e6ceea891dcc9f2a Mon Sep 17 00:00:00 2001
Date: Mon, 29 Nov 2021 17:04:06 +0100
Subject: [PATCH] SODIMM 22 , cleared for watchdog
arch/arm/mach-tegra/board-colibri_t30.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
#endif
2.30.2
From a09e957ab2d61808a0ff6a16244a06c251047746 Mon Sep 17 00:00:00 2001
Date: Tue, 30 Nov 2021 12:57:50 +0100
Subject: [PATCH] SODIMM 22 was still being used an input
index bf022d082dec..641342092de8 100644
@@ -796,7 +796,7 @@ static struct gpio_keys_button colibri_t30_keys[] = {
- GPIO_KEY(KEY_VOLUMEUP, PDD7, 1, 0), /* SODIMM pin 22 */
+ /* GPIO_KEY(KEY_VOLUMEUP, PDD7, 1, 0), /\* SODIMM pin 22 *\/ */
Iris X16-20 */
2.30.2
index 9b6ef7b116ea..8deda7ce51db 100644
@@ -1543,8 +1543,8 @@ static struct tegra_usb_platform_data tegra_ehci3_utmi_pdata = {
.hot_plug = true,
.power_off_on_suspend = true,
.remote_wakeup_supported = true,
- .vbus_gpio = USBH_PEN,
- .vbus_gpio_inverted = 1,
+ .vbus_gpio = -1, //USBH_PEN,
+ .vbus_gpio_inverted = 0, //1
.vbus_reg = NULL,
