When is support for the newer libgpiod going to be added for the NVida apalis devices , to replace the deprecated /sys/class/gpio/ structure. oecore-x86_64/environment-setup-armv7at2hf-neon-angstrom-linux-gnueabi cross compiler library currently doesnt support the newer libs
Hi @jpogge and Welcome to the Toradex Community!
Could you provide the version of the Hardware (including Carrier Board) and Software of your module?
What is your application?
What exactly are you trying to do?
