[core]
idle-time=0
require-input=false
xwayland=true
modules=screen-share.so
# uncomment line below to use kiosk shell
#shell=kiosk-shell.so
[shell]
background-image=
background-color=0x00000000
panel-position=none
locking=false
allow-zap=false
num-workspaces=1
[keyboard]
vt-switching=false
# uncomment the [output] line below if you set any output configuration
[output]
# you must uncomment the "name” line and provide the name of the output interface being customized, otherwise, changes will not apply
name=DPI-1
# uncomment line below to configure screen rotation/flipping
#transform=rotate-90
# uncomment line below to redirect the output; supported by kiosk shell
#app-ids=my-app-id
# uncomment line below to turn off the output
#mode=off
# uncomment line below to set an output resolution. Run for example 'cat /sys/class/drm/card1-HDMI-A-1/modes' to list the available modes.
mode=240x320@69.1
# or use the more detailed (mode=dotclock hdisp hsyncstart hsyncend htotal vdisp vsyncstart vsyncend vtotal hflag vflag)
#mode=146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
# uncomment line below to make this output a clone of another
#same-as=DPI-1
#For multi-display support and other configurations, please read the article: https://developer.toradex.com/knowledge-base/working-with-weston-on-torizoncore
i) I will double check the datasheet timings
ii) Not sure if the mode property is required. There seems to be only one supported mode (240x320), so I would guess it would default to that. I can try without it, and see if it makes any difference.
