Layout related query on Toradex SoM
We are using the Toradex Verdin iMX8M Plus Quad 4GB IT SoM in our design. The system includes five Ethernet ports, with the first port connected directly to the Toradex SoM. This port operates at 1 Gbps.
We are observing a failure during the Conducted Susceptibility (CS) test on the 1 Gbps Ethernet port when operating at its full speed. The failure occurs within the 39 MHz to 41 MHz frequency range.
The remaining four Ethernet ports operate at 100 Mbps and do not exhibit this issue during CS testing. These four ports are driven through an Ethernet switch IC.
Please refer to the attached images showing the Ethernet section layout and routing for further analysis. We would appreciate your support in identifying the possible root cause and recommending any design improvements or mitigation measures to address this issue.
Questions:
  1. Could you please provide Toradex’s recommended guidelines for 1 Gbps signal routing?
  2. Do you have any reference designs that you could share with us?
  3. Is trace guarding required for internal signal layers?
  4. Could you please provide the clearance requirements for internal traces and any recommendations regarding trace guarding?
We would like to schedule a call to discuss the issue in more detail. Kindly let us know your availability at your convenience.
Parimal
Hello Parimal,
I can help address your layout and routing questions for the Gigabit Ethernet port on the Verdin iMX8M Plus. Let me provide guidance based on Toradex’s documentation.
1. Toradex Guidelines for 1 Gbps Signal Routing
PCB Stack-Up Recommendations
For high-speed interfaces like Gigabit Ethernet, Toradex recommends specific stack-up configurations. A six-layer stack-up is preferred for designs with high-speed signals(1):
  • Layer 1 (Top): High-speed signals - Microstrip traces (90Ω ±15%)
  • Layer 2: Power Plane
  • Layer 3: Reference Plane (Power or Ground)
  • Layer 4: Reference Plane (Power or Ground)
  • Layer 5: Buried Microstrip (60Ω ±15%)
  • Layer 6 (Bottom): High-speed signals(1)
Trace Impedance Requirements
For Ethernet signals, the recommended impedances are(2):
  • Single-ended impedance: 55Ω
  • Differential impedance: 95Ω
The trace geometries depend on your stack-up. For a four-layer board(2):
  • Layers 1, 8 (Microstrip): W1 = 150µm, S1 = 165µm
  • Layers 3, 6 (Stripline): W1 = 140µm, S1 = 155µm
2. Reference Designs
The Verdin iMX8M Plus uses the Microchip KSZ9131 Gigabit Ethernet PHY on-module(3). The MDI interface pinout is documented in the datasheet(3), showing the four differential pairs (MDI0-MDI3) and LED signals.
For your carrier board design, you should follow the Layout Design Guide(2)(1)(4) which provides comprehensive routing recommendations.
3. Trace Guarding for Internal Signal Layers
Based on the documentation, trace guarding is not explicitly required for internal layers. However, the following spacing guidelines apply(2):
Spacing Requirements
For Ethernet differential pairs on different layer types(2):
  • Microstrip layers: 7 mils spacing between signal traces and any other signal trace
  • Stripline layers: 7 mils spacing between signal traces and any other signal trace
Critical Layout Considerations
Signal Return Path: This is crucial for your CS test issue. When routing high-speed signals(4):
  • Route signals over an unbroken reference plane(4)
  • If the reference plane is broken (split), place stitching capacitors of 1µF within 0.050 inches of vias where the reference jump occurs(4)
  • Avoid routing high-speed signals over plane splits(4)
Component Placement: High-speed signal connections should play a major role in placement decisions(2). Avoid crossing high-speed signals through careful component placement.
Layer Transitions: When signals change layers(4):
  • Place stitching vias close to layer change vias to allow return current to change ground planes
  • For differential signals, switching ground vias should be placed symmetrically(4)
  • If switching to a layer with different reference net (ground to power plane), stitching capacitors are required(4)
4. Clearance Requirements and Recommendations
Minimum Clearances
For Ethernet (55Ω single-ended, 95Ω differential)(2):
  • Spacing from any other signal: 7 mils minimum
  • Intra-pair spacing: 165µm (microstrip) or 155µm (stripline)
Additional Recommendations
Avoid Via Plane Voids: Be aware of voids in reference planes created when placing vias close together. Ensure adequate separation between vias, and sometimes it’s better to place fewer ground and power vias to reduce via voids(4).
Reference Plane Considerations:
  • High-speed signals on top layer should reference the ground plane on layer 2(1)
  • Stitching capacitors (10nF to 100nF) are needed when using power planes as reference(4)
  • Avoid routing high-speed signals on the edge of reference planes or close to PCB borders(4)
Potential Root Cause Analysis
Given your CS test failure at 39-41 MHz on the 1 Gbps port, consider:
  1. Return path discontinuities - Check for plane splits under the Ethernet traces
  2. Inadequate stitching - Verify stitching capacitors/vias at layer transitions
  3. Reference plane integrity - Ensure unbroken ground plane under all Ethernet traces
  4. Via stub resonances - The 39-41 MHz range could indicate resonance issues
Next Steps
For detailed design review and discussion, I recommend:
  1. Visit the Toradex Community to post your layout images and engage with other developers
  2. Review the complete Layout Design Guide sections on signal return paths and reference plane design(4)
  3. Verify your design follows the stack-up recommendations(1)
