The IOCTLs supported by the Serial Port Driver are listed here, but there is no IOCTL for reading the buffer directly. To read the UART buffer directly, a custom driver would need to be developed.
You can try to disable DMA:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UARTx]
"EnableDMA"=dword:0
Actually, disabling DMA did work. I just needed to reboot the Colibri. Problem solved!!!
Thanks Alex!
