Large splash screen cannot be programmed with the UpdateTool
In issue number 49571 you say that large splash screen cannot be programmed with the UpdateTool.
Do you have a time scale to resolve this issue ?
As far as I understand the only way to get splash screen now is to go back to Easy Installer and to do production programming.
Thank you !
Dear @Frax222
The issue is already resolved. Please use the Update Tool which comes with Image V1.5 or any later version.
I just found that the roadmap was not refreshed and still shows a pending release V1.5. I arranged that the information will be updated.
Regards, Andy
I have just downloaded Image imx6 1.5 and 1.4. The files UpdateTool_CE7.exe are identical in both releases.
Kind regards
maybe I should have said it clearer: it still does not work. I get the message “Update Failed”.
Binary comparing update tools from BSP 1.4 and 1.5 does not show a difference.
Kind regards
Dear @Frax222
It seems that we missed to include the latest Update.exe into the V1.5 image.
I currently cannot access the regular build system, but I locally built a preliminary Update Tool based on the library which is able to flash larger splash screens. Please test whether this works for you:
We will take care that a properly generated version of the tool will be included into the image download package.
Regards, Andy
Hello Andy,
this now works - I can flash splash screen without error message - however it is not shown when booting - but maybe this is another thread …
Kind regards
