Hi We are using the iMx6ULL IT 512M DDR 512M Flash Col on Volia EVK.
Following Yocto build instructions on your site (with latest v5 BSP) and using EasyInstaller to write the image I get the following Kernel crash.
Is there issue with this latest BSP?
Using Toradex build of latest console image things boot fine.
log:
U-Boot 2020.07-5.0.0-devel+git.f867d6dc9514 (Aug 28 2020 - 17:28:01 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 47C
Reset cause: POR
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from NAND... OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6ULL 512MB IT V1.1A, Serial# 06652675
Net: Could not get PHY for FEC1: addr 2
No ethernet found.
Booting from NAND...
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd5
ubi0: scanning is finished
ubi0: attached mtd5 (name "ubi", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 5/2, WL threshold: 4096, image sequence number: 6215580
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
No size specified -> Using max size (6428432)
Read 6428432 bytes from volume kernel to 81000000
No size specified -> Using max size (52827)
Read 52827 bytes from volume dtb to 82100000
Kernel image @ 0x81000000 [ 0x000000 - 0x621710 ]
## Flattened Device Tree blob at 82100000
Booting using the fdt blob at 0x82100000
Loading Device Tree to 8fff0000, end 8ffffe5a ... OK
Updating MTD partitions...
Starting kernel ...
[ 0.000000] Linux version 5.4.47-5.0.0-devel+git.e4db2a7562a1 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP Thu Sep 3 14:00:52 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX6ULL 256MB on Colibri Evaluation Board V3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] percpu: Embedded 15 pages/cpu s31692 r8192 d21556 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 374832K/524288K available (8192K kernel code, 713K rwdata, 2656K rodata, 1024K init, 382K bss, 18384K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000055] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002843] Console: colour dummy device 80x30
[ 0.003550] printk: console [tty1] enabled
[ 0.003619] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.003689] pid_max: default: 32768 minimum: 301
[ 0.004025] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.004095] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.005733] CPU: Testing write buffer coherency: ok
[ 0.006429] CPU0: update cpu_capacity 1024
[ 0.006487] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.007810] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.008148] rcu: Hierarchical SRCU implementation.
[ 0.008862] smp: Bringing up secondary CPUs ...
[ 0.008921] smp: Brought up 1 node, 1 CPU
[ 0.008959] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.008995] CPU: All CPU(s) started in SVC mode.
[ 0.009851] devtmpfs: initialized
[ 0.030155] random: get_random_u32 called from bucket_table_alloc+0x58/0x14c with crng_init=0
[ 0.031273] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.031989] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.032084] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.041752] pinctrl core: initialized pinctrl subsystem
[ 0.043979] NET: Registered protocol family 16
[ 0.058222] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.060346] cpuidle: using governor menu
[ 0.074562] vdd3p0: supplied by regulator-dummy
[ 0.075817] cpu: supplied by regulator-dummy
[ 0.077033] vddsoc: supplied by regulator-dummy
[ 0.098753] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.098825] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.100526] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.102703] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.170345] soc_in: supplied by +V3.3
[ 0.171202] eth_phy: supplied by +V3.3
[ 0.333956] regulator-usbh-vbus GPIO handle specifies active low - ignored
[ 0.334126] VCC_USB[1-4]: supplied by 5V
[ 0.337047] SCSI subsystem initialized
[ 0.337719] usbcore: registered new interface driver usbfs
[ 0.337879] usbcore: registered new interface driver hub
[ 0.338132] usbcore: registered new device driver usb
[ 0.340934] i2c i2c-0: IMX I2C adapter registered
[ 0.342684] i2c i2c-1: IMX I2C adapter registered
[ 0.343201] videodev: Linux video capture interface: v2.00
[ 0.343372] pps_core: LinuxPPS API ver. 1 registered
[ 0.343415] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.343501] PTP clock support registered
[ 0.344094] Advanced Linux Sound Architecture Driver Initialized.
[ 0.346756] clocksource: Switched to clocksource mxc_timer1
[ 0.347137] VFS: Disk quotas dquot_6.6.0
[ 0.347338] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.368371] thermal_sys: Registered thermal governor 'step_wise'
[ 0.369036] NET: Registered protocol family 2
[ 0.370371] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.370492] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.370630] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.370811] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.371026] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.371116] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.371524] NET: Registered protocol family 1
[ 0.372747] RPC: Registered named UNIX socket transport module.
[ 0.372811] RPC: Registered udp transport module.
[ 0.372845] RPC: Registered tcp transport module.
[ 0.372877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.374436] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.377575] Bus freq driver module loaded
[ 0.380304] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.395005] NFS: Registering the id_resolver key type
[ 0.395116] Key type id_resolver registered
[ 0.395152] Key type id_legacy registered
[ 0.395207] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.397359] Key type cifs.idmap registered
[ 0.397434] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.398557] fuse: init (API version 7.31)
[ 0.491922] Key type asymmetric registered
[ 0.492016] io scheduler mq-deadline registered
[ 0.492054] io scheduler kyber registered
[ 0.495721] mxsfb 21c8000.lcdif: 21c8000.lcdif supply lcd not found, using dummy regulator
[ 0.496227] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.496291] mxsfb 21c8000.lcdif: Using timings from kernel parameters
[ 0.607922] Console: switching to colour frame buffer device 80x30
[ 0.627373] mxsfb 21c8000.lcdif: initialized
[ 0.634897] mxs-dma 1804000.dma-apbh: initialized
[ 0.642734] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 23, base_baud = 5000000) is a IMX
[ 1.311987] printk: console [ttymxc0] enabled
[ 1.321844] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 62, base_baud = 5000000) is a IMX
[ 1.338990] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 63, base_baud = 5000000) is a IMX
[ 1.389017] imx_rngc 2284000.rng: Freescale RNGC registered.
[ 1.421179] brd: module loaded
[ 1.445518] loop: module loaded
[ 1.456569] libphy: Fixed MDIO Bus: probed
[ 1.467919] pps pps0: new PPS source ptp0
[ 1.478719] libphy: fec_enet_mii_bus: probed
[ 1.489831] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.500786] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.511220] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.520795] usbcore: registered new interface driver usb-storage
[ 1.531100] usbcore: registered new interface driver usbserial_generic
[ 1.541633] usbserial: USB Serial support registered for generic
[ 1.551548] usbcore: registered new interface driver cp210x
[ 1.560987] usbserial: USB Serial support registered for cp210x
[ 1.570720] usbcore: registered new interface driver ftdi_sio
[ 1.580320] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.595084] usbcore: registered new interface driver pl2303
[ 1.604515] usbserial: USB Serial support registered for pl2303
[ 1.618134] imx_usb 2184000.usb: No over current polarity defined
[ 1.628816] imx_usb 2184200.usb: No over current polarity defined
[ 1.643108] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.651843] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.686829] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.697632] hub 1-0:1.0: USB hub found
[ 1.704809] hub 1-0:1.0: 1 port detected
[ 1.721794] input: AD7879 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-002c/input/input0
[ 1.743947] rtc-ds1307 0-0068: registered as rtc0
[ 1.754587] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.764867] i2c /dev entries driver
[ 1.773355] IR NEC protocol handler initialized
[ 1.781503] IR RC5(x/sz) protocol handler initialized
[ 1.790049] IR RC6 protocol handler initialized
[ 1.797997] IR JVC protocol handler initialized
[ 1.805871] IR Sony protocol handler initialized
[ 1.813809] IR SANYO protocol handler initialized
[ 1.822951] IR Sharp protocol handler initialized
[ 1.830914] IR MCE Keyboard/mouse protocol handler initialized
[ 1.839979] IR XMP protocol handler initialized
[ 1.848133] pps_ldisc: PPS line discipline registered
[ 1.860025] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.870400] sdhci: Secure Digital Host Controller Interface driver
[ 1.879830] sdhci: Copyright(c) Pierre Ossman
[ 1.887273] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.898784] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 1.941309] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.958152] caam-snvs 20cc000.caam-snvs: can't get snvs clock
[ 1.967492] caam-snvs 20cc000.caam-snvs: violation handlers armed - init state
[ 1.984656] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.994009] usbcore: registered new interface driver usbhid
[ 2.003027] usbhid: USB HID core driver
[ 2.020158] NET: Registered protocol family 10
[ 2.030280] Segment Routing with IPv6
[ 2.037895] NET: Registered protocol family 17
[ 2.045723] Bridge firewalling registered
[ 2.053242] 8021q: 802.1Q VLAN Support v1.8
[ 2.060748] random: fast init done
[ 2.067905] tsn generic netlink module v1 init...
[ 2.076110] Key type dns_resolver registered
[ 2.108785] cpu cpu0: defer the cpufreq
[ 2.108785]
[ 2.121477] Registering SWP/SWPB emulation handler
[ 2.130301] registered taskstats version 1
[ 2.183830] imx_usb 2184000.usb: No over current polarity defined
[ 2.198876] mxs_phy 20c9000.usbphy: vbus is not valid
[ 2.211033] debugfs: Directory 'cpu0-dc' with parent 'soc_in' already present!
[ 2.225633] cpu cpu0: defer the cpufreq
[ 2.225633]
[ 2.241737] debugfs: Directory 'cpu0-dc' with parent 'soc_in' already present!
[ 2.256155] cpu cpu0: defer the cpufreq
[ 2.256155]
[ 2.271437] UBI error: cannot open mtd ubi, error -2
[ 2.281346] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 2.293481] debugfs: Directory 'cpu0-dc' with parent 'soc_in' already present!
[ 2.308488] cpu cpu0: defer the cpufreq
[ 2.308488]
[ 2.320708] rtc-ds1307 0-0068: setting system clock to 2020-09-08T05:49:00 UTC (1599544140)
[ 2.340019] ALSA device list:
[ 2.346359] No soundcards found.
[ 2.353934] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -19
[ 2.368963] Please append a correct "root=" boot option; here are the available partitions:
[ 2.384612] 0100 65536 ram0
[ 2.384617] (driver?)
[ 2.397858] 0101 65536 ram1
[ 2.397863] (driver?)
[ 2.410633] 0102 65536 ram2
[ 2.410638] (driver?)
[ 2.423221] 0103 65536 ram3
[ 2.423228] (driver?)
[ 2.435455] 0104 65536 ram4
[ 2.435462] (driver?)
[ 2.447524] 0105 65536 ram5
[ 2.447530] (driver?)
[ 2.459375] 0106 65536 ram6
[ 2.459381] (driver?)
[ 2.470788] 0107 65536 ram7
[ 2.470794] (driver?)
[ 2.482009] 0108 65536 ram8
[ 2.482014] (driver?)
[ 2.492883] 0109 65536 ram9
[ 2.492889] (driver?)
[ 2.503590] 010a 65536 ram10
[ 2.503595] (driver?)
[ 2.514040] 010b 65536 ram11
[ 2.514046] (driver?)
[ 2.523973] 010c 65536 ram12
[ 2.523979] (driver?)
[ 2.533766] 010d 65536 ram13
[ 2.533772] (driver?)
[ 2.543567] 010e 65536 ram14
[ 2.543572] (driver?)
[ 2.553382] 010f 65536 ram15
[ 2.553388] (driver?)
[ 2.563211] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.575457] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
