Linux BSP 2.8.7
Colibri T20 with Viola carrier board
We had 2 systems stop working out of 20 running Yocto BSP 2.8.7 and our software with not a huge amount of uptime. This was definitely caused by writing to the flash and removing power at the same time. Checking the debug output it is a corrupted file system, I can attach logs if necessary but looking at other posts it seems correct.
My question:
Does the BSP 3 deal with this problem better or is it the same for 2.8.7?
We would prefer not to update our kernel but if this will fix our problem then we have no choice.
If updating is not 100% then is there something else we can do to minimise this happening in the field?
Is there a way to repair the file system or is it a waste of time?
Thanks in advance.
