The Image is Apalis imx6 2.8b2
i followed Build U-Boot and Linux Kernel from Source Code
and try to add the splash screen to the present image
After following Splash Screen (Linux)
then done kernel compilation using the commands
make -j3 zImage LOADADDR=10008000 2>&1 | tee build.log
make imx6q-apalis-eval.dtb
then did the kernel update using the commands
cp ~/linux-toradex/arch/arm/boot/uImage /media///
cp ~/linux-toradex/arch/arm/boot/dts/imx6q-apalis-eval.dtb /media///
then flashed the updated image using
run setupdate
run update_kernel
run update_fdt
while running
[FAILED] Failed to start Load Kernel Modules.
[FAILED] Failed to start Load default USB gadget schema g1.schema.
two errors were found . After searching in toradex community we found that we can the errors by kernel deployment
While kernel deployment the following error has occured.
skanray@skanray-System-Product-Name:~/linux-toradex$ sudo -E make INSTALL_MOD_PATH=/home/skanray/Images/Apalis-iMX6_LXDE-Image_2.8.2/rootfs/ modules_install
./scripts/gcc-version.sh: line 25: arm-linux-gnueabihf-gcc: command not found
./scripts/gcc-version.sh: line 26: arm-linux-gnueabihf-gcc: command not found
make: arm-linux-gnueabihf-gcc: Command not found
cp: cannot stat './modules.order': No such file or directory
Makefile:1227: recipe for target '_modinst_' failed
make: *** [_modinst_] Error 1
Please look on this.
