I am following the instructions as per the following link for my ApalisiMX8 Ixora board and have successfully flashed the Toradex Easy installer many times before using the same procedure.
Earlier when I tried to flash the easy installer, the board was simply not being recognized.
I also tried 2 different USB-B cables but got the same response.
Normally, as soon as you go into recovery , a USB sound is heard and then the recovery script runs successfully.
Following this first report, I removed the SOM, waited for a while and once again inserted the SOM and now I can go into recovery mode and run the script.
I am trying to install the Torizon version (tried both the Torizon versions shown -with and without preempt_RT) and I could not see any login screen which normally comes up. However I could load the board with the wayland Toradex minimal reference image.
I have also connected via the serial UART (see the attached image) after loading the Torizon image and powering up again. Please can you let me know what is happening here.
