That command does not produce a running container. However if I use this command I get a working Weston container.
docker container run -d --name=weston --net=host \
--cap-add CAP_SYS_TTY_CONFIG \
-v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
--device-cgroup-rule="c 4:* rmw" --device-cgroup-rule="c 253:* rmw" \
--device-cgroup-rule="c 13:* rmw" --device-cgroup-rule="c 226:* rmw" \
--device-cgroup-rule="c 10:223 rmw" --device-cgroup-rule="c 199:0 rmw" \
torizon/weston-imx8:4 \
--developer
With the above container running, I now get this error.
✔ Container torizon-weston-1 Created 0.0s
✔ Container torizon-qt-1 Created 0.4s
Attaching to qt-1
qt-1 | qt.qpa.wayland: Failed to initialize EGL display 3001
qt-1 | Hello Torizon!
qt-1 | QRhiGles2: Failed to create temporary context
qt-1 | QRhiGles2: Failed to create context
qt-1 | Failed to create RHI (backend 2)
qt-1 | Failed to initialize graphics backend for OpenGL.
qt-1 exited with code 133
