Issue with SD Card Preparation for Apalis TK1
I am also getting the issue while creating SD card bootable for Apalis TK1 and for that I ran the following command:
./update.sh -m 2 -o /media/usaername/NewVol/
and got the Error Script aborted unexpectedly... as output, like:
root@hscuser-OptiPlex-3046:~/APALISTK1-Buils/Apalis-TK1_LXDE-Image_2.7.2# ./update.sh -m 2 -o
/media/hscuser/New\ Volume1/
Apalis TK1 rootfs specified
Image file apalis-tk1.img has been successfully generated!
Creating MBR file and do the partitioning
0+0 records in
0+0 records out
0 bytes (0 B) copied, 7.8444e-05 s, 0.0 kB/s
Model:  (file)
Disk /home/hscuser/APALISTK1-Buils/Apalis-TK1_LXDE-Image_2.7.2/apalis-tk1_bin/mbr.bin: 30760960s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End        Size       Type     File system  Flags
 1      8192s   40959s     32768s     primary               lba
 2      40960s  30719999s  30679040s  primary
Creating VFAT partition image with the kernel
mkfs.fat 3.0.26 (2014-03-07)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
Creating rootfs partition image
504+0 records in
504+0 records out
528482304 bytes (528 MB) copied, 0.207803 s, 2.5 GB/s
mke2fs 1.42.9 (4-Feb-2014)
Discarding device blocks: done
Filesystem label=rootfs
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
Stride=0 blocks, Stripe width=0 blocks
129024 inodes, 516096 blocks
25804 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67633152
63 block groups
8192 blocks per group, 8192 fragments per group
2048 inodes per group
Superblock backups stored on blocks:
        8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
tune2fs 1.42.9 (4-Feb-2014)
Setting maximal mount count to -1
Setting interval between checks to 0 seconds
umount: mnt/tdx-rootfs: not mounted
I have followed http://developer.toradex.com/knowledge-base/installing-nvidia-jetpack-with-l4t-on-apalis-tk1 to install nvidia jetpack with l4t on apalis-tk1 and to test it i wanted to boot it from SD card but update script is not working.
Please suggest what to do next to boot from SD, OR anyone has done NFS boot for Apalis-TK1 then please share how to do NFS boot.
Thanks in advance
Nitesh
Our update script prepares an update media for later update from within U-Boot’s run setupdate; run update commands and can not be used for direct booting. For more information concerning alternate ways how one may boot an embedded Linux system have a look at the following article on our developer website.
What exactly went wrong with the update script in your case I’m not sure but could you post what exact contents your SD card now has e.g. doing ls -lR /media/hscuser/New\ Volume1/ or tree /media/hscuser/New\ Volume1/?
NFS booting is covered here.
