Issue to with ROOTFS_POSTPROCESS_COMMAND
Hello All,
I am trying to execute a custom ROOTFS_POSTPROCESS_COMMAND to set the system locale. But It is always failing.
Here is my custom script.
update_locale() {
    localectl set-locale  LANG=en_US.UTF-8 LANGUAGE=en_US:en
ROOTFS_POSTPROCESS_COMMAND += "\
                     update_locale; \
Error message :
localectl: not found
WARNING: exit code 127 from a shell command.
But I have checked. The build host has localectl as well as the rootfs also has localectl.
Any help would really be appreciated.
Hi @xdaco
Could you provide the version of the software of your module?
Have you done any changes to the Software? If yes, could you share these changes.
Hi @jaski.tx
We are using Colibri-iMX7-eMMC_LXDE-Image-Tezi_2.8b6 by building it from the source with our own carrier board-specific device tree file.
Hi @xdaco
Which file did you add this script to in the open-embedded Environment?
What is the distribution ( uname -a ) of your build host?
Hi @jaski.tx
To customize the os image I have created angstrom-lxde-image.bbappend in which I have a couple of shell function which customizes the image
for our specific requirements.
One of such post-process function was
update_locale() {
This was failing. But now, I have been able to achieve the same end result by editing
/etc/profile.d/locale.sh and /etc/locale.conf . This is a workaround. I would like to solve the issue if possible.
The kernel I am using is : 4.9.166-rt125-2.8.6+gd899927
The complete ouput of uname --all is
$ uname --all
Linux bor-carrier-board 4.9.166-rt125-2.8.6+gd899927 #1 SMP Thu Apr 9 22:24:48 UTC 2020 armv7l armv7l armv7l GNU/Linux
HI @xdaco
Good that you found a workaround. Thanks for your feedback.
I will look into this issue and come back to you.
Hi @xdaco
It is possible to run the command if you enter the full path /usr/bin/localectl. However depending on the Linux Distribution and Os Settings, you might need sudo rights to run this command (For example if you use Fedora 27).
