I am using a Apalis I.MX8QM module with Apalid motherboard V1.1A
I am trying to boot a the latest EsayInstaller version on a USB stick with U_boot
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06540929
BuildInfo:
SCFW 494c97f3, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
Easy Installer version /etc/issue : Toradex Easy Installer 2.4
I put the content of Apalis-iMX8_Reference-Minimal-Image-Tezi_5.3.0+build.10.tar
and remane boot-tezi.scr file to boot.scr
on a USB stick then plud it on the USB 3.0 Host port (blue one)
When issue issue the below command in U-boot I got:
Apalis iMX8 # run bootcmd_usb0
starting USB...
USB0: Port not available.
USB1: clkvld is incorrect = 0xd0b03827
XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 1 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: General Rev: 1.00 Prod: USB Flash Disk
Type: Removable Hard Disk
Capacity: 3824.0 MB = 3.7 GB (7831552 x 512)
... is now current device
Scanning usb 0:1...
Found U-Boot script /boot.scr
3087 bytes read in 25 ms (120.1 KiB/s)
## Executing script at 86000000
43 bytes read in 20 ms (2 KiB/s)
106496 bytes read in 28 ms (3.6 MiB/s)
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
47056280 bytes read in 1963 ms (22.9 MiB/s)
Bootargs: quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall clk_ignore_unused pci=nomsi
## Loading kernel from FIT Image at 8a000000 ...
Could not find configuration node
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
3087 bytes read in 26 ms (115.2 KiB/s)
43 bytes read in 21 ms (2 KiB/s)
106496 bytes read in 29 ms (3.5 MiB/s)
47056280 bytes read in 1962 ms (22.9 MiB/s)
Did I do something wrong ?
Erwan
