I am trying to boot FreeRTOS Hello world elf on the Toradex Board. But Getting some memory issue.
I first the below steps for remoteproc1 where the state is running but when trying with Hello world elf is not working
Flashing SD image .
Using uuu and the files imx-boot-variant-alt-imx95-19x19-verdin-sd.bin-flash_alt
, imx-image-full-imx95-19x19-verdin.wic
flash it to SD memory, these file are included in pre-built images.
E.g. on windows terminal:
uuu.exe -b sd_all .\imx-boot-variant-alt-imx95-19x19-verdin-sd.bin-flash_alt .\imx-image-full-imx95-19x19-verdin.wic
**Modifying uboot environment.**
iMX 95 Verdin
Stop in uboot
Add to mmcargs `pd_ignore_unused clk_ignore_unused` and boot. E.g.:
u-boot=> setenv mmcargs "setenv bootargs ${cpuidle} ${jh_clk} ${mcore_args} console=${console} root=${mmcroot} pd_ignore_unused clk_ignore_unused"
u-boot=> saveenv
Saving Environment to MMC... Writing to MMC(1)... OK
u-boot=> boot
After that, remote-proc can be used normally, I also share a log example
root@imx95-19x19-verdin:~# cat /sys/devices/platform/imx95-cm7/remoteproc/remoteproc1/state
offline
root@imx95-19x19-verdin:~# echo ~/rpmsg_lite_str_echo_rtos.elf > /sys/devices/platform/imx95-cm7/remoteproc/remoteproc1/firmware
root@imx95-19x19-verdin:~# echo start > /sys/devices/platform/imx95-cm7/remoteproc/remoteproc1/state
running
I am attaching the error document.
See 'systemctl status weston.service' for details.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
NXP i.MX Release Distro 6.6-scarthgap imx95-19x19-verdin ttyLP0
imx95-19x19-verdin login: root
root@imx95-19x19-verdin:~# cd /sys/devices/platform/imx95-cm7/
driver/ modalias power/ subsystem/ uevent
driver_override of_node/ remoteproc/ supplier:platform:42430000.mailbox/
root@imx95-19x19-verdin:~# cd /sys/devices/platform/imx95-cm7/remoteproc/
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc# ls
remoteproc1
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc# cd remoteproc1/
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# ls
coredump device firmware name power recovery state subsystem uevent
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# cat firmware
rproc-imx-rproc-fw
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo /usr/lib/firmware/
NeutronFirmware.elf imx95-verdin-evk_m7_TCM_rpmsg_lite_pingpong_rtos_linux_remote.elf
NeutronKernels.bin imx95-verdin-evk_m7_TCM_rpmsg_lite_str_echo_rtos.elf
freertos_hello_sm_cm7.elf imx95-verdin-evk_m7_TCM_sai_low_power_audio.elf
imx95-15x15-evk_m7_TCM_power_mode_switch.elf jailhouse.bin
imx95-15x15-evk_m7_TCM_rpmsg_lite_pingpong_rtos_linux_remote.elf mali_csffw.bin
imx95-15x15-evk_m7_TCM_rpmsg_lite_str_echo_rtos.elf nxp/
imx95-15x15-evk_m7_TCM_sai_low_power_audio.elf regulatory.db
imx95-19x19-evk_m7_TCM_flexcan_linux.elf regulatory.db.p7s
imx95-19x19-evk_m7_TCM_low_power_wakeword.elf tee-header_v2.bin
imx95-19x19-evk_m7_TCM_netc_share.elf tee-pageable_v2.bin
imx95-19x19-evk_m7_TCM_power_mode_switch.elf tee-pager_v2.bin
imx95-19x19-evk_m7_TCM_rpmsg_lite_pingpong_rtos_linux_remote.elf tee-raw.bin
imx95-19x19-evk_m7_TCM_rpmsg_lite_str_echo_rtos.elf tee.bin
imx95-19x19-evk_m7_TCM_sai_low_power_audio.elf tee.elf
imx95-verdin-evk_m7_TCM_power_mode_switch.elf wave633c_codec_fw.bin
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo /usr/lib/firmware/imx95-verdin-evk_m7_TCM_rpmsg_lite_pingpong_rtos_linux_remote.elf > firmware
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# cat state
offline
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo start > state
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# sync
running
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo stop > state
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo /usr/lib/firmware/imx95-verdin-evk_m7_TCM_rpmsg_lite_str_echo_rtos.elf > firmware
root@imx95-19x19-verdin:/sys/devices/platform/imx95-cm7/remoteproc/remoteproc1# echo /usr/lib/firmware/freertos_hello_sm_cm7.elf > firmware
[ 195.984790] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[ 195.991056] Modules linked in: rpmsg_ctrl rpmsg_char snd_soc_fsl_asoc_card mxc_jpeg_encdec crct10dif_ce snd_soc_imx_card polyval_ce polyval_generic snd_soc_imx_audmux v4l2_jpeg snd_soc_fsl_micfil snd_soc_fsl_sai snd_soc_fsl_utils snd_soc_wm8904 ap130x imx_pcm_dma flexcan can_dev pwm_fan fuse
[ 196.016866] CPU: 2 PID: 680 Comm: sh Not tainted 6.6.36-lts-next-gd23d64eea511 #1
[ 196.024334] Hardware name: NXP i.MX95 19X19 board (DT)
[ 196.029457] pstate: a0400009 (NzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 196.036407] pc : __memcpy+0x110/0x240
[ 196.040064] lr : rproc_start+0x64/0x1b4
[ 196.043895] sp : ffff8000849f3be0
[ 196.047196] x29: ffff8000849f3be0 x28: ffff0000853ad880 x27: 0000000000000000
[ 196.054321] x26: 0000000000000000 x25: ffff000084c11e00 x24: ffff00008c3bcc20
[ 196.061445] x23: 0000000000000000 x22: ffff000080945038 x21: ffff000080945000
[ 196.068575] x20: 0000000000000000 x19: ffff800083075000 x18: fffffffffffedbb0
[ 196.075779] x17: 72656572662f6572 x16: 61776d7269662f62 x15: 0000000000000040
Message from syslogd@imx95-19x19-verdin at Tue Feb 27 18:00:41 2024 ...
kernel: Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[ 196.095288] x14: ffff800083075000 x13: 0000000000007d08 x12: 0000000000000001
[ 196.102412] x11: ffff0000809454d0 x10: 0000000000000003 x9 : ffff80008170f070
[ 196.109536] x8 : ffff80008170f070 x7 : 0000000000000001 x6 : ffff800084b47d08
[ 196.116660] x5 : ffff8000830750a0 x4 : 00000000000000a0 x3 : 0000000000000000
[ 196.123784] x2 : 00000000000000a0 x1 : 0000000000000000 x0 : ffff800083075000
[ 196.130915] Call trace:
[ 196.133360] __memcpy+0x110/0x240
[ 196.136669] rproc_boot+0x198/0x57c
[ 196.140154] state_store+0x40/0x104
[ 196.143637] dev_attr_store+0x18/0x2c
[ 196.147303] sysfs_kf_write+0x44/0x54
[ 196.150963] kernfs_fop_write_iter+0x120/0x1cc
[ 196.155400] vfs_write+0x1c0/0x300
[ 196.158804] ksys_write+0x74/0x10c
[ 196.162201] __arm64_sys_write+0x1c/0x28
[ 196.166118] invoke_syscall+0x48/0x114
[ 196.169856] el0_svc_common.constprop.0+0xc0/0xe0
[ 196.174553] do_el0_svc+0x1c/0x28
[ 196.177864] el0_svc+0x40/0xe4
[ 196.180921] el0t_64_sync_handler+0x120/0x12c
[ 196.185265] el0t_64_sync+0x190/0x194
[ 196.188932] Code: cb01000e b4fffc2e eb0201df 540004a3 (a940342c)
[ 196.195014] ---[ end trace 0000000000000000 ]---
Please help.
For build imx-mkimage - using NXP Files (Is there anything else?)
For Hello world elf - NXP SDK 24_10 Latest one
Please help, further details message.
