Yes, when I installed the OS, I set the password to “toradex” for the Torizon OS. If it were a firewall issue, then I shouldn’t be able to open the terminal using the connected device in VS Code. Since I can open the terminal, what could be the bigger issue I’m facing?
I was able to pull successfully, but after running the task “rsync-torizon-generic”, I started getting the above error @jeremias.tx @ToradexAI
Thanks for the conversation! I’ve reached my limit of replies in this thread.
If you still have questions, feel free to start a new one. I’m happy to help!
Well it has to be a network issue of some kind. The error message is fairly straightforward:
ssh: connect to host 192.168.225.246 port 6502: Connection refused
I believe if you open a terminal this way it’s just default ssh on the default port of 22. Here you can see it’s trying to use port 6502, maybe this port is busy or blocked in your setup. Is the IP address right?
It’s difficult to say anything specific without being in your exact network setup.
@jeremias.tx @ToradexAI Thank you for your support. Now my issue is solved.
Thanks for the conversation! I've reached my limit of replies in this thread.
If you still have questions, feel free to start a new one. I'm happy to help!
Glad we were able to assist you.
