Hello everyone,
I wanted to share a solution that worked for me, in case anyone else is running into similar issues.
I initially tried to run my Qt application on a Toradex device using the eglfs
platform. In my Yocto layer, the default QT_QPA_PLATFORM
was being set in the default-qt-envs.bb
file like this:
QT_QPA_PLATFORM ?= "${@bb.utils.contains('DISTRO_FEATURES', 'opengl', 'eglfs', 'linuxfb', d)}"
After some digging, I found that eglfs
wasn’t working correctly on my board. It seems this might be due to the galcore
driver (used by the Vivante GPU). From what I understand, eglfs
requires a full DRM/KMS backend to function correctly — something that drivers like etnaviv
or modesetting
provide. However, galcore
is likely more limited or headless and does not expose the full DRM/KMS API, which may lead to failures when using eglfs
Solution: Switch to wayland-egl
Switching to Wayland by setting:
QT_QPA_PLATFORM=wayland-egl
allowed my application to run successfully. Weston was already running on the device, so using Wayland as the backend worked seamlessly.
Hopefully this helps others who are using Qt (boot2qt) with Toradex and running into display issues with eglfs
regards
Alvaro
