I’m trying to run a camera that uses MIPI CSI 2, however I’m having problems and I would like to receive a help from you. I will describe my environment:
- Base Board Ixora v1.1
- Module Apalis iMX6Q 2GB;
- The Video Decoder ISL79987IRZ;
- Kernel is 4.9.87;
- Yocto branch rocko;
- Ported Driver: L4.1.15_ISL7998x_Surroundview_Patch_20161122.zip (https://community.nxp.com/docs/DOC-339457);
The driver is already integrated into the kernel and enabled. With the command “make menuconfig” it is in:
-> Device Drivers
-> Multimedia support
-> V4L platform devices
-> MXC Video For Linux Video Capture
-> MXC Camera/V4L2 PRP Features support
<*> Intersil ISL7998x Video Decoder support
<*>mxc VADC support
<*>Select Overlay Rounting (Queue ipu device for overlay library)
<*>Pre-processor Encoder library
<*>IPU CSI Encoder library)
Parts of the Device Tree imx6qdl-apalis-ixora-v1.1.dtsi file:
v4l2_cap_0: v4l2_cap_0 {
compatible = "fsl,imx6q-v4l2-capture";
ipu_id = <0>;
csi_id = <0>;
mclk_source = <0>;
v4l2_cap_2: v4l2_cap_2 { // mipi-csi2 camera
ipu_id = <0>;
csi_id = <1>;
mclk_source = <0>;
&i2c3 {
isl7998x_mipi: isl7998x_mipi@44 {
compatible = "intersil,isl7998x_mipi";
reg = <0x44>;
clocks = <&clks 200>;
clock-names = "csi_mclk";
mclk = <27000000>;
mclk_source = <0>;
csi_id = <1>;
&mipi_csi {
ipu_id = <0>;
csi_id = <1>;
v_channel = <0>;
lanes = <2>;
When loading the kernel, the following messages are displayed:
dmesg | grep csi
[ 0.250861] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu-1 csi-1
[ 0.250873] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 1.795969] mxc_v4l2_master_attach: ipu(0:0)/csi(0:1)/mipi(0:0) doesn't match
[ 1.795987] mxc_v4l2_master_attach: ipu0:/csi0 parallel attached isl7998x:mxc_v4l2_cap0
[ 1.796005] mxc_v4l2_master_attach: ipu0:/csi1 parallel attached isl7998x:mxc_v4l2_cap1
[ 1.796017] mxc_v4l2_master_attach: ipu(1:0)/csi(0:1)/mipi(0:0) doesn't match
[ 1.796021] mxc_v4l2_master_attach: ipu(1:0)/csi(0:0)/mipi(0:0) doesn't match
[ 1.796030] mxc_v4l2_master_attach: ipu(1:0)/csi(1:1)/mipi(0:0) doesn't match
[ 1.796036] mxc_v4l2_master_attach: ipu(1:0)/csi(0:1)/mipi(0:0) doesn't match
[ 1.796041] mxc_v4l2_master_attach: ipu(1:0)/csi(1:0)/mipi(0:0) doesn't match
[ 1.796046] mxc_v4l2_master_attach: ipu(1:0)/csi(0:0)/mipi(0:0) doesn't match
[ 13.420543] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 432 Mbps
[ 13.420556] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0xc.
dmesg | grep isl
[ 1.796051] isl7998x_mipi is found
See above for the driver to the end of the probe function successfully.
Accessing / dev has the following video options:
ls -la /dev/video*
crw-rw---- 1 root video 81, 2 Dec 17 15:20 /dev/video0
crw-rw---- 1 root video 81, 3 Dec 17 15:20 /dev/video1
crw-rw---- 1 root video 81, 0 Dec 17 15:20 /dev/video16
crw-rw---- 1 root video 81, 1 Dec 17 15:20 /dev/video17
Running the gst-launch-1.0 command has the following error:
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! autovideosink
or
gst-launch-1.0 v4l2src device=/dev/video1 ! videoconvert ! autovideosink
[ 506.984147] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 432 Mbps
[ 506.991994] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0xc.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 507.664909] UYVY
[ 518.233107] ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate a buffer
Additional debug info:
../../../git/sys/v4l2/gstv4l2src.c(866): gst_v4l2src_create (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0
Execution ended after 0:00:10.610824001
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
gst-launch-1.0 v4l2src device=/dev/video16 ! videoconvert ! autovideosink
or
gst-launch-1.0 v4l2src device=/dev/video17 ! videoconvert ! autovideosink
Returns that they are not capture devices.
Could anyone help?
Thank you all!
