Is there a frame buffer driver available on linux for a 2.8 inch TFT LCD display?
I am trying to connect a 2.8 inch TFT LCD display with 18bit LVDS interface. Is there driver on linux that Ican directly use or modify and use for this purpose?
Thanks in advance,
What is the module and image version on the module? Can you share the output of
cat /etc/issue
There is a driver called ldb which is able to drive LVDS. The Article Display Output, Resolution and Timings article shows how to use the driver and enable the display output.
Such a small display usually has a custom resolution and hence needs custom display timings. Use the display-timings subnode in the device tree to specify this.
