Invert logic of RTS port - apalis-uart2(ttyLP3)
How can I invert RTS pin logic on apalis-uart2?
I connected pins of RS485 transceiver DE, DI to apalis UART3_RTS_B.
For transmission I need a high logic level on this output but it is low, I try to use “rs485-rts-active-low” but it didn’t change anything.
“rs485-rts-active-low” works perfectly for apalis-uart1.
My module: Apalis IMX8QP 2GB
without “rs485-rts-active-low”:
/* Apalis UART2 */
&lpuart3 {
pinctrl-names = “default”;
pinctrl-0 = <&pinctrl_lpuart3>;
linux,rs485-enabled-at-boot-time;
with “rs485-rts-active-low”:
/* Apalis UART2 */
&lpuart3 {
rs485-rts-active-low;
pinctrl_lpuart3:
/* Apalis UART2 */
pinctrl_lpuart3: lpuart3grp {
fsl,pins =
<IMX8QM_LVDS1_I2C1_SCL_DMA_UART3_TX 0x06000020>,
<IMX8QM_LVDS1_I2C1_SDA_DMA_UART3_RX 0x06000020>,
<IMX8QM_ENET1_RGMII_RXC_DMA_UART3_CTS_B 0x06000020>,
<IMX8QM_ENET1_RGMII_TXD3_DMA_UART3_RTS_B 0x06000020>;
can you share a quick snippet of you schematic and how you connected it on you carrier board?
Matthias Gohlke
