Install the cab file on WinCE and save this installation
I installed cab file installation. And it worked . But it dosn’t work after reboot colibri imx6.
add this question. I safe registry after installation.
Could please let us know:
  • Which cab did you install?
  • Which image version do you currently run?
  • Can you manually modify / add any registry key which survives a reboot?
  • cab - Own service drivers pack
  • imx6_wince7_bsp_1.1 imx6_wince7_workspace_1.1
  • It’s not clear from me “Can you manually modify / add any registry key which survives a reboot?”
Just try to add a registry key manually using the registry editor (Start->Programs->ColibriTools->RegEdit). Add any key there in HKLM, save the registry and reboot. Does this work?
