For a Colibri iMX6DL 512MB V1.1A attached to an Aster V1.1B,
I need to install the operating system (WinCE6 or WEC2013) and our software automatically with no connection to a pc.
The steps should be approximately as follows:
- The operator switches on power to the system
- The system boots into Easy Installer in unattended mode, and uses the SD card as source to install the software
- When finished, the operator switches off power
Is this possible, or do I need to install Easy Installer manually to the board, in order to setup a new operating system?
