This build appears to be different than in the past as I tried both methods which were reported to work in the following link:
In this build they do not work. I notice that the kernel which is packaged into the Tezi folder is not a file named in the /deploy/images/verdin-imx8mp/ folder. This is likely why using do_deploy:append to relink Image.gz to the initramfs version did not work in my build. I need to know what has been modified in the current build which defines which kernel is built into the Tezi folder.
