Inbuilt keyborad not showing in colibri t20 board
i am try to folder name or any other things inbuilt keyboard not visible, i am check the all options in wince7 but its not showing
Did you already try to clear the registry with the Update Tool and reboot the device again? In our default image, the keyboard should always appear if you click in a text field other than you disabled the keyboard in the registry. Did you do any other special configuration.
