Hello Matej,
Thank you for your question!
Once your i.MX8MP with the Mallow board has secure boot enabled and the closing fuse has been set, the device enforces signature verification on the bootloader. This means you cannot flash or boot an unsigned U-Boot image—the device will reject it, and tools like Toradex Easy Installer will also not function in this state. This is an intended feature to ensure the integrity and authenticity of your bootloader (source).
To update or flash a new (custom) U-Boot on such a device, you must:
- Build your custom U-Boot, then sign it with the SAME credentials (private keys) that you used for the initial secure boot setup.
- Flash the signed U-Boot using procedures that are compatible with secure boot, such as updating it from a running environment (e.g., using Linux tools or U-Boot’s own update commands), as long as the update process does not require bypassing secure boot verification.
It is also recommended in future projects to thoroughly test your boot setup before setting the final “closing” fuse, as this action is irreversible (source).
If you need detailed instructions on building, signing, or deploying a U-Boot update for secure boot, I can guide you.
