Good day.
I’m trying to implement inter-core data exchange using a DDR buffer for a large amount of data. I am using a Verdin devkit on IMX8MP. Kernel version 5.15. I have already implemented communication via RPMSG using “/dev/rpmsg_ctrl0”.
Now I want to allocate memory in DDR from CMA space and send the address to the CortexM via the RPMSG message. To do this, I deal with an NXP example for “Low Power Audio Application - AN12195SW”. I took the “rmtcore_shm” driver code from the patches and compiled it in the kernel environment via devshell.
Then I installed the module on the system “rmtcore-shm.ko”
root@verdin-imx8mp-14762892:~# insmod ./rmtcore-shm.ko
[ 235.945223] RMTCORE module started!
But the new device “/dev/rmtcore_shm” did not appear in the system. And when I try to open it I get an error:
rmtcore_shm_fd = open(RMTCORE_SHM_DEV, O_RDWR);
"Unable to open device /dev/rmtcore_shm"
I may need to make changes to the device files. Right now my overlay for RPMSG looks like this:
/dts-v1/;
/plugin/;
#include <dt-bindings/clock/imx8mp-clock.h>
compatible = "toradex,verdin-imx8mp";
rmtcore_shm {
compatible = "fsl,rmtcore-shm";
status = "ok";
imx8mp-cm7 {
compatible = "fsl,imx8mp-cm7";
clocks = <&clk IMX8MP_CLK_M7_DIV>;
mbox-names = "tx", "rx", "rxdb";
mboxes = <&mu 0 1
&mu 1 1
&mu 3 1>;
memory-region = <&vdevbuffer>, <&vdev0vring0>, <&vdev0vring1>, <&rsc_table>, <&m7_reserved>;
rsc-da = <0x55000000>;
syscon = <&src>;
fsl,startup-delay-ms = <500>;
&i2c3 {
status = "disabled";
&pwm4 {
&resmem {
#address-cells = <2>;
#size-cells = <2>;
m7_reserved: m7@0x80000000 {
no-map;
reg = <0 0x80000000 0 0x1000000>;
vdev0vring0: vdev0vring0@55000000 {
no-map;
reg = <0 0x55000000 0 0x8000>;
vdev0vring1: vdev0vring1@55008000 {
no-map;
reg = <0 0x55008000 0 0x8000>;
vdevbuffer: vdevbuffer@55400000 {
compatible = "shared-dma-pool";
no-map;
reg = <0 0x55400000 0 0x100000>;
rsc_table: rsc_table@550ff000 {
no-map;
reg = <0 0x550ff000 0 0x1000>;
&sai3 {
&sdma3 {
&mu {
&uart4 {
Can you please tell me what changes need to be made so that /dev/rmtcore_shm appears in the system and I can get access to memory allocation in DDR? If someone has already come across this solution and an example.
Thanks in advance for any help.
