during Linux kernel boot I get the following error in the console:
[ 1.267553] reg-fixed-voltage regulator-module-eth1phy: Failed to register regulator: -517
I’m using Toradex BSP 5.6.0-devel-202202 with an Verdin Plus V1.0 Module and a custom carrier board. For the carrier board I created a device-tree file that includes the .dtsi files from Toradex. So I did not patch or modify the file imx8mp-verdin.dtsi, where this On-SOM-module regulator “regulator-module-eth1phy” is defined.
What is the problem here and how can I get rid of the error?
The eth1 interface is actually working, but I do not find any problems in the dev-tree.
The custom carrier board .dts file looks like this:
/dts-v1/;
#include "imx8mp-verdin.dtsi"
#include "imx8mp-verdin-nonwifi.dtsi"
model = "Toradex Verdin iMX8M Plus on Verdin Development Board";
compatible = "toradex,verdin-imx8mp-nonwifi-dev",
"toradex,verdin-imx8mp-nonwifi",
"toradex,verdin-imx8mp",
"fsl,imx8mp";
/* Carrier Board Supply +V3.3 */
reg_3p3v: regulator-3p3v {
compatible = "regulator-fixed";
regulator-max-microvolt = <3300000>;
regulator-min-microvolt = <3300000>;
regulator-name = "+V3.3_SW";
&pinctrl_uart1 {
fsl,pins = <
MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x1c4 /* SODIMM 129 */
MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x1c4 /* SODIMM 131 */
MX8MP_IOMUXC_SAI2_TXFS__UART1_DCE_CTS 0x1c4 // SODIMM 133
MX8MP_IOMUXC_SAI2_RXD0__UART1_DCE_RTS 0x1c4 // SODIMM 135
&fec {
fsl,magic-packet;
phy-supply = <®_3p3v>;
phy-handle = <ðphy1>;
phy-mode = "rgmii-id";
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_fec>;
pinctrl-1 = <&pinctrl_fec_sleep>;
mdio {
#address-cells = <1>;
#size-cells = <0>;
/delete-node/ ethernet-phy@7;
ethphy1: ethernet-phy@3 {
compatible = "ethernet-phy-ieee802.3-c22";
interrupt-parent = <&gpio4>;
interrupts = <18 IRQ_TYPE_LEVEL_LOW>;
micrel,led-mode = <0>;
eee-broken-100tx;
eee-broken-1000t;
reg = <3>;
&rtc_i2c {
aux-voltage-chargeable = <1>;
/* Verdin SPI_1 */
&ecspi1 {
/* enabled in dev-tree overlay for et1100 */
status = "disabled";
spidev10: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <10000000>;
/* EEPROM on display adapter boards */
&eeprom_display_adapter {
/* EEPROM on Verdin Development board */
&eeprom_carrier_board {
&eqos {
&flexcan1 {
&flexcan2 {
/* Verdin QSPI_1 */
&flexspi {
/* Current measurement into module VCC */
&hwmon {
&hwmon_temp {
/* Verdin I2C_2_DSI */
&i2c2 {
&i2c3 {
&i2c4 {
/* Verdin PCIE_1 */
&pcie {
epdev_on-supply = <®_3p3v>;
&pcie_phy{
/* Verdin PWM_1 */
&pwm1 {
/* Verdin PWM_2 */
&pwm2 {
/* Verdin PWM_3_DSI */
&pwm3 {
®_usdhc2_vmmc {
vin-supply = <®_3p3v>;
/* VERDIN I2S_1 */
&sai1 {
/* Verdin UART_1 */
&uart1 {
/* Verdin UART_2 */
&uart2 {
/* Verdin UART_3, used as the Linux Console */
&uart3 {
/* Verdin USB_1 */
&usb3_phy0 {
&usb3_0 {
&usb_dwc3_0 {
/* Verdin USB_2 */
&usb3_phy1 {
&usb3_1 {
&usb_dwc3_1 {
/* Verdin SD_1 */
&usdhc2 {
Thanks in advance!
Regards, Ralph
