In our new project we are looking for a platform that utilize the IMX8MP processor together with a AMOLED display Multi-Inno MI0548BO that can work using command mode to save power.
Is that something that has been verified i.e. IMX8MP using MIPI in Command mode?
To provide you with the most accurate guidance for your IMX8MP project with the AMOLED display Multi-Inno MI0548BO in command mode, I’d like to understand your setup better.
Could you let me know:
Which specific Toradex module are you using (e.g., Verdin iMX8M Plus)?
What operating system and version are you planning to run?
Data lanes: Four data lanes (DSI_1_D0_P/N through DSI_1_D3_P/N)
I2C control: I2C_2_DSI_SCL/SDA for DDC or controlling DSI bridges
Backlight control: PWM_3_DSI for display backlight brightness control
Enable signal: GPIO_10_DSI for display backlight enable
Command Mode Considerations
While the documentation confirms MIPI DSI support with low power operation capabilities (1), the specific verification of command mode operation with your Multi-Inno MI0548BO AMOLED display would require:
Device tree configuration for your specific display panel
Driver compatibility verification for command mode operation
Power management setup to leverage the low power features
The Verdin iMX8M Plus supports multiple display controllers, allowing flexibility in display configuration while maintaining compatibility with other Verdin modules (1).
For your specific AMOLED display integration, you would need to develop appropriate device tree overlays and potentially custom display drivers to fully utilize command mode power-saving features.
