I have question abut the WDOG3 clock source.
Is it one independent clock source and WDOG3 continues the operation in case external XTAL stops operation.
VERDIN IMX8MP Q 4GB WBIT
Hi @Vladimir !
Just for clarification, are you referring to hardware watchdog or real-time clock (software watchdog)?
There is watchdog functionality that is set up via software. In some cases, there might be software errors that render the watchdog unfunctional and your module might hang.
Depending on your security requirements, it could be beneficial to use a hardware watchdog, it is advised to use an external watchdog.
Also, which carrier board are you using? Or is it a custom carrier board?
I use the Watchdog, Watchdog Control Register (WDOG3_WCR) located at 302A_0000 from M7 core.
The SRC->M7RCR set to perform the system reset if WDOG3 expires.
At same time RDC used to protect the WDOG3 and SRC from modifications other SW except M7.
But the major question I have: dows WDOG3 uses one independent clock source or it demepds on the external cristal? Is WDOG3 fully independent from the other components state? For example STM C0Plus contains WDOG. This WDOG uses own internal clock source and operates inown clock domain, it is fully independent and considered as “external”. Is the WDOG3 built in the same fashion and can be considered equivalent to the external WDOG, e.g. it uses own fully independent from the other components clock doman and is not dependent on other clock/bus components?
Mfg
Hello @Vladimir,
Looking at the IMX8MPRM, I found this table:
The clock that is used as the source for the counter is the ipg_clk_32k, which has the special functionality of being able to switch to an internal clock source in case the external clock is not available (due to low power mode for instance).
I don’t know exactly how this compares to the STM clock source, but it seems that it will keep running in most situations.
Rafael Beims
