We want to use CLK_24M_REF_OUT (pin 208) 24 Mhz clock output to feed our FPGA if it is possible.
But we need to know the accuracy of this clock like initial offset error in ppm, temperature coefficient and aging parameter. I couldn’t see them in the module datasheet. Is it possible to share them?
We only have the specifications of the crystal:
Tolerance @25°C: 30ppm
Frequency Stability: 30ppm
Operating Temperature: -40 to 85°C
Aging per year: 3ppm max
Unfortunately, we do not have the temperature coefficient. Please also keep in mind that the external circuit (e.g. load capacitance) can influence the clock frequency.
