majd.m
April 1, 2020, 10:59am
1
I would like to ask, is it possible in the current toradex yocto platform for iMX8QM to build a linux with PREEMPT RT patch directly?
I already added in the local.conf file in yocto
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-rt"
The image builds without errors, but after flashing it on the iMX8, it shows that it doesnt have RT patch.
Majd
Hi @majd.m
Which OpenEmbedded branch did you compile?
Have you done any other changes to local.conf? If yes, could you share these changes?
majd.m
April 2, 2020, 9:36am
3
Hi @jaski.tx ,
Thank you for the quick response,
The OpenEmbedded branch is thud.
The other local.conf is just some qt libraries.
MAGE_INSTALL_append = " qtquickcontrols qtquickcontrols2 qtwebsockets qtdeclarative qtwayland"
IMAGE_INSTALL_append = " libwebsockets"
the image is built with qt: “qt5-x11-image”
Best regards, Majd
Hi @majd.m
You can basically just switch the DISTRO_mx8 to tdx-xwayland-rt. I did following changes to the conf/local.conf:
# Use this distro
DISTRO = "tdx-x11"
#DISTRO_mx8 = "tdx-xwayland"
DISTRO_mx8 = "tdx-xwayland-rt"
ACCEPT_FSL_EULA = "1"
After that, I was able to build the image with bitbake -k qt5-x11-image
Kind regards
Diego
majd.m
April 8, 2020, 8:23am
5
Thank you. Seem to be working. I will test the image soon.
You are welcome. Thanks for your feedback.
