Hi @hfranco.tx,
I tried using overlay from your link:
tpm_tis@0 {
compatible = "infineon,slb9670";
spi-max-frequency = <10000000>;
But without reg property I’m getting error in dmesg:
spi_master spi0: /bus@5a000000/spi@5a000000/tpm_tis@0 has no valid 'reg' property (-22)
spi_master spi0: Failed to create SPI device for /bus@5a000000/spi@5a000000/tpm_tis@0
So I put back “reg = <0>;” inside tpm_tis node. I’ve also tried different spi-max-frequency values (20 MHz, 1MHz, 500 kHz) but still no output from tpm_tis_spi module.
Regards,
Mateusz
