I am using mrvl mwifiex driver. Actually this driver not working fine. It is connecting and after sometime automatically disconnected and throwing errors on the screen.
OK. I’ve contacted your account rep who is going to reach out because we need an NDA to be able to share the NXP proprietary driver.
In the meantime, can you share how you are using the wifi? Are you using just normal STA mode or are you using AP mode? Are you simultaneously using BT? If so, what profiles? Can you also share the error message you see?
Drew
The problem has been solved wifi is working fine. Now I am facing one more issue. While doing modprobe sometime I am getting wlan0 instead of uap0. Why this is happening ?
Hi @rohitsharma,
I don’t know. I’ve never seen that particular symptom but I don’t normally remove and insert the kernel modules very often. Are you able to reproduce this reliably? Does it ever happen on first boot/first modprobe?
Drew
