Imx8 ixora1.2 start boot
hello all
i have got a imx8 apalis and ixora 1.2
how to boot it ??
are there a good tutorial easyinstaller??
thank you
Hi @hhami ,
A good start is the Quick Start Guide found here : Quickstart Guide - Toradex
If you’re looking for more information about the Toradex Easy Installer, then have a look at this:
If you’re looking to recover a module you can first put the module into recovery mode and then flash Toradex Easy Installer.
Hope this helps.
Kevin
thanks kevin.tx
Hi @hhami !
Please mark the message with the solution, so the Community knows which content helped you :slight_smile:
