I need to test fuse write capability on an Apalis iMX8 QM. I would like to do this from the OS (EL1). I can read the fuses via an SMC call, however, an SMC write to the customer fuse bits (row 275) doesn’t set the the fuse.
Before I try this with uboot I thought I should ask if anyone has programmed the customer bits successfully.
In the future I will need to increase the partition sizes from the default of 4MB. I don’t want to commit to a size today so thought the “Customer” fuses would be a good way to test write capability for the future.
I was hoping for confirmation that the Customer fuses are indeed for my use. I don’t want to brick the board.
