i have install the Boot2Qt 5.14.2 on Imx8QM and when i try the qt video example all videos i tried start with a flickering error.
I’m have tried with Boot2Qt 5.14.1 and i have the same situation.
can you help me?
L.
can you help me?
L.
HI @lucio.schioppo and Welcome to the Toradex Community!
Which Display on which interface are you using?
Could you share the dmesg.log?
Do you see the flickering also when you don’t run any video?
i’m using the capacitive Touch Display 10.1" LVDS.
The flickering is only when i try to run videos with the Qt MediaPlayer example, it’s seems like a codec error. I have try different .mp4 file but nothing change.
thanks
Lucio
Dear @lucio.schioppo
Unfortunately this is a know issue at the moment on boot2qt. We hope it will be fixed when they switch to a newer version of the BSP. Currently the only option is to switch to software rendering by deleting the v4l2 gstreamer plugin. The following should work:
find /usr/lib/* -name "libv4l2*" -delete
Stefan
I have try the command “find /usr/lib/* -name “libv4l2*” -delete” but in all directory libv4l2 not exists.
I use the B2Qt 5.14.2.
Lucio
Sorry, I mentioned the wrong filename… You can delete /usr/lib/gstreamer-1.0/libgstvideo4linux2.so that should be the correct one. After that it should fallback to software decoding.
Stefan
Thank you so much !!! work well!
