Imx8 and osm-gps-map library
Hello everyone,
May I ask if I can add osm-gps-map library to apalis imx8 multimedia image?
the image i have does not support osm-gps-map.
is it doable or not?
Rama
Hi @rama.aloufee ,
Thanks for reaching out to Toradex.
Would you be able to state what image you are using in your setup? What Kernel version are you using?
Furthermore, for the record it would be helpful to also know the HW version.
Kevin
Hi @kevin.tx ,
image: multimedia image from easy installer for apalis imx8
kernel version: 5.4.129-rt61-5.4.0-devel+git.cb88cc157bfb
hardware version: Ixora Carrier Board V1.2A
Apalis iMX8 QuadMax V1.1
Hi @rama.aloufee,
We don’t have anything out of the box for Open Street Map.
I’ve searched layers.openembedded.org for a recipe and I only could find the OSM Cartography using ROS:
https://layers.openembedded.org/layerindex/branch/master/recipes/?q=open+street+map
You’ll need to create the recipe if this doesn’t fit your needs.
Hiago.
