Hardware: Colibri iMX7D 512MB
Just checking to see if Silverlight/XAML projects are supported on the iMX7D on WEC2013. I have seen some other modules mentioned but not the iMX7D. After installing the hardware SDK I am not having any luck creating a silverlight project.
Create new in VS2015 fails with little error info. When I try porting a WEC7 project I previosly worked on it gives an error that _tmainStartup cannot be found. Wondering if I need to consider some other options for building out my UI.
