We have a customized system. We do not use a carrier board, we have our own hardware.
Kernel version is 4.9.76.0000 and we adapted uboot 2016.11.
It happens always, if the watchdog was running.
If you don’t see this behaviour with toradex software, do you somehow reset PMIC in uboot? Is there maybe something which we had overseen when adapting uboot? Do you know how to reset/disable PMIC watchdog out of uboot?
So you have your own custom carrier board.
When the watchdog is active, its normal that it will do a reset.
In our regular images, the watchdog is not active, you have to trigger it to make it active.
And if there is an external reset, the module gets reset and watchdog is not more active. So what did you change in UBoot exactly?
Yes.
That’s what I would expect. But somehow the watchdog is still running in our case.
We did not change the partition but we overwrote “bootcmd” enviroment variable.
Hi @jaski.tx
No this is not a blocker point for us. It’s just not very practical because we do ftp update out of uboot during developing. And it would be nice to have this somewhere stated to avoid that someone else is searching the cause of this behaviour like we did…
Anyway, thanks a lot for your help and patience and let me know when this gets fixed some day.
