I tried to find out what exact memory the M4 uses to run. I just found out that it is tightly coupled memory. I would especially need information about error detection / correction capabilities of the used memory.
Hi
M4 uses the internal memory (64KB) dedicated to M4, which is named as tightly coupled memory. This memory does not have any ECC.
Best regards, Jaski
