I tried to load the easy installer2.0b3 from sd card.
To verify these logs are from a healthy module (although the warnings and errors vary from time to time and sometimes it stucks on booting kernel…):
U-Boot 2016.11-1.0b1+g07edca0 (Jan 01 1970 - 00:00:00 +0000)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 38C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1A, Serial# 06476989
Net: FEC0
Colibri iMX7 #
Colibri iMX7 #
Colibri iMX7 #
Colibri iMX7 # run bootcmd_mmc1
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
reading /boot.scr
471 bytes read in 10 ms (45.9 KiB/s)
## Executing script at 87000000
reading /tezi.itb
36423988 bytes read in 1585 ms (21.9 MiB/s)
## Loading kernel from FIT Image at 82100000 ...
Using 'config@imx7d-emmc' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.9.87-2.8.3+gdef4502031f6
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000f0
Data Size: 5740192 Bytes = 5.5 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 489f42eaa8bf0282f136bc4bbdf69a83
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x82679878
Data Size: 30547968 Bytes = 29.1 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: 882e04c342e4bd49379e57c24c84f00c
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@imx7d-emmc' fdt subimage
Description: Colibri iMX7 Dual 1GB eMMC Device Tree
Type: Flat Device Tree
Data Start: 0x843b1184
Data Size: 45385 Bytes = 44.3 KiB
Architecture: ARM
Hash algo: md5
Hash value: 353b795deb63f90f301ebb17789e21c5
Booting using the fdt blob at 0x843b1184
Loading Kernel Image ... OK
Loading Device Tree to 8fff1000, end 8ffff148 ... OK
Starting kernel ...
[ 1.040341] CPU1: failed to come online
[ 1.393601] spi_imx 30840000.ecspi: dma setup error -19, use pio
[ 1.625416] caam 30900000.caam: failed to acquire DECO 0
[ 1.630756] caam 30900000.caam: failed to instantiate RNG
[ 1.675017] coresight-etm3x 3007d000.etm: ETM arch init failed
Running /etc/rc.local...
TDX_VER_ID="Colibri-iMX7_ToradexEasyInstaller_2.0b3-20191029"
Starting udev
[ 2.621360] udevd[146]: specified group 'kvm' unknown
$Starting haveged: haveged: haveged starting up
[ OK ]
System time was Thu Jan 1 00:00:03 UTC 1970.
Setting the System Clock using the Hardware Clock as reference...
hwclock: can't open '/dev/misc/rtc': No such file or directory
System Clock set. System local time is now Thu Jan 1 00:00:03 UTC 1970.
Tue Oct 29 19:18:24 UTC 2019
Saving the System Clock time to the Hardware Clock...
Hardware Clock updated to Tue Oct 29 19:18:24 UTC 2019.
Certificates for RDP not found in /var/volatile
Generating RSA private key, 2048 bit long modulus (2 primes)
.......................................................haveged: haveged: ver: 1.9.2; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 12/40; sz: 15012/57848
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 8.00451
haveged: haveged: fills: 0, generated: 0
e is 65537 (0x010001)
Signature ok
subject=C = CH, ST = Luzern, L = Luzern, O = Toradex, CN = (none)
Getting Private key
Certificate for RDP successfully generated
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using RDP. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
on the bad module i got:
CPU: Extended Commercial temperature grade (-20C to 105C) at 34C
Reset cause: POR
DRAM: 1 GiB
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1A, Serial# 06475694
Net: FEC0
Colibri iMX7 #
Colibri iMX7 # usb start
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1: [HANGS HERE - POWER CYCLE]
CPU: Extended Commercial temperature grade (-20C to 105C) at 35C
Reset cause: POR
DRAM: 1 GiB
Video: 640x480x18
In: serial
Out: serial
Err: serial
Net: FEC0
Scanning mmc 1:1...
reading /boot.scr
reading /tezi.itb
36423988 bytes read in 1584 ms (21.9 MiB/s)
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: md5
Type: RAMDisk Image
Architecture: ARM
OS: Linux
Hash algo: md5
Architecture: ARM
Hash algo: md5
Starting kernel ...
Reset cause: POR
DRAM: 1 GiB
Video: 640x480x18
In: serial
Out: serial
Err: serial
Net: FEC0
Scanning mmc 1:1...
reading /boot.scr
471 bytes read in 11 ms (41 KiB/s)
reading /tezi.itb
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: md5
Type: RAMDisk Image
Architecture: ARM
OS: Linux
Hash algo: md5
Architecture: ARM
Hash algo: md5
Starting kernel ...
[ 1.040334] CPU1: failed to come online
[ 1.392941] spi_imx 30840000.ecspi: dma setup error -19, use pio
[HANGS HERE]
Since ESD damage is my best guess i verified our esd protection circuit via 15kV pulses. As of parts it is the nearly same as the reference design and withsand the test quite well.
Mentaly my further steps would be the following:
- ask you what to do next
- put esd dirctly on the modules usb lines to see if it results in the same errors as my 4 damaged modules.
- send the modules to you
jfi :
The stable 1.8 failed like it always does from any source:
Scanning mmc 1:1...
reading /boot.scr
464 bytes read in 11 ms (41 KiB/s)
reading /tezi.itb
21374744 bytes read in 938 ms (21.7 MiB/s)
Description: Linux Kernel 4.1
Type: Kernel Image
Data Start: 0x821000dc
Data Size: 5308472 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Hash algo: md5
Hash value: 910fc4bfe6325ca943e1af0824a15957
Type: RAMDisk Image
Data Start: 0x826101fc
Data Size: 15929344 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Hash algo: md5
Hash value: bf0a406d6fa572c48f601023ca980bd2
Data Start: 0x83557184
Data Size: 45372 Bytes = 44.3 KiB
Architecture: ARM
Hash algo: md5
Hash value: b34140d2c5400aef8309a51bb7486030
Booting using the fdt blob at 0x83557184
Loading Device Tree to 8fff1000, end 8ffff13b ... OK
Starting kernel ...
[ 1.000306] CPU1: failed to come online
[ 1.296890] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
[ 1.469152] caam 30900000.caam: failed to acquire DECO 0
[ 1.503763] caam 30900000.caam: failed to acquire DECO 0
[ 1.536471] caam 30900000.caam: failed to acquire DECO 0
[ 1.570209] caam 30900000.caam: failed to acquire DECO 0
[ 1.607340] caam 30900000.caam: failed to acquire DECO 0
[ 1.641477] caam 30900000.caam: failed to acquire DECO 0
[ 1.676604] caam 30900000.caam: failed to acquire DECO 0
[ 1.713708] caam 30900000.caam: failed to acquire DECO 0
[ 1.747781] caam 30900000.caam: failed to acquire DECO 0
[ 1.781859] caam 30900000.caam: failed to acquire DECO 0
[ 1.815930] caam 30900000.caam: failed to acquire DECO 0
[ 1.850038] caam 30900000.caam: failed to acquire DECO 0
[ 1.884111] caam 30900000.caam: failed to acquire DECO 0
[ 1.918184] caam 30900000.caam: failed to acquire DECO 0
[ 1.952269] caam 30900000.caam: failed to acquire DECO 0
[ 1.986344] caam 30900000.caam: failed to acquire DECO 0
[ 2.019454] caam 30900000.caam: failed to acquire DECO 0
[ 2.054561] caam 30900000.caam: failed to acquire DECO 0
[ 2.089671] caam 30900000.caam: failed to acquire DECO 0
[ 2.121725] caam 30900000.caam: failed to acquire DECO 0
[ 2.153792] caam 30900000.caam: failed to acquire DECO 0
[ 2.185863] caam 30900000.caam: failed to acquire DECO 0
[ 2.217950] caam 30900000.caam: failed to acquire DECO 0
[ 2.251061] caam 30900000.caam: failed to acquire DECO 0
[ 2.256385] caam 30900000.caam: failed to instantiate RNG
[ 2.262093] Trying to vfree() nonexistent vm area (b4063000)
[ 2.269643] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[ 2.277745] pgd = 80004000
[ 2.280520] [00000004] *pgd=00000000
[ 2.284126] Internal error: Oops: 805 [#1] SMP ARM
[ 2.288922] Modules linked in:
[ 2.292004] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.1.44-1.8.0+gf3637519a6aa #1
[ 2.300881] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 2.306634] task: b407c000 ti: b4062000 task.ti: b4062000
[ 2.312043] PC is at caam_sm_startup+0x8c/0x3cc
[ 2.316580] LR is at device_add+0x150/0x568
[ 2.320773] pc : [<804c03dc>] lr : [<8037504c>] psr: a0000113
[ 2.320773] sp : b4063ec8 ip : 00000000 fp : 00000000
[ 2.332256] r10: 00000000 r9 : 808f4624 r8 : 00000000
[ 2.337489] r7 : 808dab9c r6 : b779d838 r5 : b4176a10 r4 : b4211840
[ 2.344023] r3 : b5386400 r2 : b5386410 r1 : 00000000 r0 : b5386400
[ 2.350559] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 2.357875] Control: 10c5387d Table: 8000406a DAC: 00000015
[ 2.363627] Process swapper/0 (pid: 1, stack limit = 0xb4062210)
[ 2.369641] Stack: (0xb4063ec8 to 0xb4064000)
[ 2.374009] 3ec0: 804d476c 808dab9c 00000000 b5386400 b4176a10 8090b920
[ 2.382198] 3ee0: 8090b920 b53718c0 808dab9c 00000000 808f4624 00000007 00000000 808dabec
[ 2.390387] 3f00: 8090b920 80009678 80911c64 808f4600 00000000 80141aac 80911d00 b4113700
[ 2.398575] 3f20: 00000000 809105c4 80885748 000000ac b7fffb3f 800453a4 00000000 80822284
[ 2.406763] 3f40: 00000006 00000006 b7fffb4a 807d11a4 809105ac 000000ac 80951000 000000ac
[ 2.414952] 3f60: 80951000 80951000 808fe0e4 808f461c 808f4624 808b4db8 00000006 00000006
[ 2.423140] 3f80: 808b45a0 80654750 00000000 80654750 00000000 00000000 00000000 00000000
[ 2.431327] 3fa0: 00000000 80654758 00000000 8000f3a8 00000000 00000000 00000000 00000000
[ 2.439515] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.447703] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff 10080000
[ 2.455899] [<804c03dc>] (caam_sm_startup) from [<808dabec>] (caam_sm_init+0x50/0x58)
[ 2.463744] [<808dabec>] (caam_sm_init) from [<80009678>] (do_one_initcall+0x8c/0x1d0)
[ 2.471675] [<80009678>] (do_one_initcall) from [<808b4db8>] (kernel_init_freeable+0x144/0x1d4)
[ 2.480389] [<808b4db8>] (kernel_init_freeable) from [<80654758>] (kernel_init+0x8/0xe8)
[ 2.488495] [<80654758>] (kernel_init) from [<8000f3a8>] (ret_from_fork+0x14/0x2c)
[ 2.496076] Code: e59d300c e2832010 e5843008 e5834068 (e58a2004)
[ 2.502214] ---[ end trace 5b4cfc5db27edc94 ]---
[ 2.506861] mmc0: MAN_BKOPS_EN bit is not set
[ 2.511321] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.511321]
[ 2.520468] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.520468]
