We are working on calibri-imx7 controller.
Loading os image is done. but it show Data abort exception error. What can be done to solve this issue?
alt text
We got below error while doing reflashing and running below bat file
Windows: recovery-windows.bat.
Interface 0 claimed HAB security
state: development mode (0x56787856)
== work item filename u-boot.imx load_size 0 bytes load_addr 0x83f00000
dcd 1 clear_dcd 0 plug 0 jump_mode 2
jump_addr 0x00000000
== end work item loading DCD table @0x910000<<<-588, 1024 bytes>>> succeeded
(status 0x128a8a12)loading binary file(u-boot.imx) to
877ff400, skip=0, fsize=55c00 type=aa<<<351232, 351232 bytes>>> succeeded
(status 0x88888888) jumping to
0x877ff400 config file parse
recovery\\mx7_usb_sdp_uboot.conf
Trying to open device vid=0x1b67
pid=0x4000 claim interface failed
Press any key to continue . . .
This is not error at all. succeeded (status 0x88888888) jumping to 0x877ff400 tells you that TEZI image is started already. From now you should be able to a) use display and mouse connected to “Colibri”, or b) connect to “Colibri” using VNC software. B could be either via ethernet or USB RNDIS. RNDIS IP is fixed and known 192.168.11.1, ethernet IP may be discovered using serial console, just enter ifconfig command and see IP address.
Could you please use Toradex Easy Installer v2.06 and follow steps described here - https://developer.toradex.com/software/toradex-easy-installer#load-toradex-easy-installer-from-usb-otg
