Imx6ull BSP6 update device tree
Linux BSP 6
Previously using BSP 3 i wsa able to build my dtb file and then place it onto a memory card.
Then i used ‘ubiupdatevol /dev/ubi0_1 devicetreename.dtb’
This then updated the device tree and it worked.
I have now moved to BSP6 and although i have built the new dtb file, i cannot upgrade my module using the above.
In previous topics i have seen ‘run update_fdt’ , but i just get ‘run not found’
How do i now update the device tree ?
Hello @adrian ,
You can try the procedure described here: Device Tree Technical Overview | Toradex Developer Center
Best regards.
Josep
