I downloaded the workspace and BSP from iMX6 WEC Software | Toradex Developer Center (for CE8)
and I found that it doesn’t build even after using the correct pbxml ( file that was sent to me https://share.toradex.com/l6uw477htoamp75). I believe there is some problem in your BSP. The build fails giving the following error:
Could you please send me the working workspace and BSP for Colobri iMX6?
------ Build started: Project: IMX6_Core2013, Configuration: Toradex COLIBRI VYBRID ARMV7 Debug Platform Builder (_TGTCPU) ------
Starting Build: blddemo -q
Microsoft .NET Framework 4.x Full installed.
Wince ARMV7 CEBASE COLIBRIVYBRIDBIN Development Environment for arihos
“C:\Windows\system32\cmd.exe” /d /c “blddemo -q”
BLDLOGS: BUILDMSG: Saving last failed log as “C:\WINCE800\build.lkb.log”.
BLDLOGS: BUILDMSG: Starting: BldDemo1.bat -q
BLDLOGS: BUILDMSG: Logs at “C:\WINCE800\build.*”.
BLDDEMO: BUILDMSG: BldDemo started at 11:22:27.29 on Thu 06/09/2016
BLDDEMO: BUILDMSG: Generating OS Design Folders
BLDDEMO: BUILDMSG: Done Generating OS Design Folders
BLDDEMO: BUILDMSG: Generating OS Design Files to C:\Users\arihos\Desktop\IMX6_Core2013\Wince800\COLIBRIVYBRIDBIN_ARMV7_Debug\oak
BLDDEMO: BUILDMSG: Done Generating OS Design Files
CEBUILD: BUILDMSG: Skipping directly to SYSGEN phase
CEBUILD: BUILDMSG: Building dep trees: winceos dcom wgi html netcf servers cellcore ossvcs shell directx ostest CEBASE
CEBUILD: BUILDMSG: Running sysgen preproc (for COMMON)
coredllhs.def : error LNK2001: unresolved external symbol GetCOMPortHandle {log=“C:\WINCE800\build.log(547)”}
‘C:\Users\arihos\Desktop\IMX6_Core2013\Wince800\COLIBRIVYBRIDBIN_ARMV7_Debug\cesysgen\sdk\lib\ARMV7\debug\coredllhs.lib’ : fatal error LNK1120: 1 unresolved externals {log=“C:\WINCE800\build.log(548)”}
NMAKE : fatal error U1077: ‘C:\WINCE800\sdk\bin\i386\ARM\link.exe’ : return code ‘0x460’ {log=“C:\WINCE800\build.log(549)”}
NMAKE : fatal error U1077: ‘C:\WINCE800\public\common\oak\Bin\i386\nmake.exe’ : return code ‘0x2’ {log=“C:\WINCE800\build.log(551)”}
NMAKE : fatal error U1077: ‘C:\WINCE800\public\common\oak\Bin\i386\nmake.exe’ : return code ‘0x2’ {log=“C:\WINCE800\build.log(553)”}
CEBUILD: BUILDMSG: There were errors building. Check C:\WINCE800\build.err
BLDDEMO: ERROR: There were errors building CEBASE. {log=“C:\WINCE800\build.log(558)”}
BLDDEMO: BUILDMSG: BldDemo ended at 11:22:33.95 on Thu 06/09/2016 (exit code 1)
BLDLOGS: BUILDMSG: Exiting: BldDemo1.bat -q (result code 1).
BLDLOGS: BUILDMSG: C:\WINCE800\build.log
BLDLOGS: BUILDMSG: C:\WINCE800\build.out
BLDLOGS: BUILDMSG: C:\WINCE800\build.err
IMX6_Core2013 - 6 error(s), 0 warning(s)
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
