Hello to everyone,
this is my first post here and I want to greet you.
I’m new on the Colibri programming, less than one month, and I’ve to say that it was going everything well.
Until now because after a registry change the OS boots but I cannot see anything in the screen.
The OS is Windows Embedded 2013 and I’ve changed two registry values to increase the screen resolution, but unfortunately I don’t remember them.
I’ve changed from 640x480 to 1024x7680abd now I cannot see the desktop the boots normally, I think since I can ping it.
So I’m asking you if there is a way to restore the registry to the factory settings.
I’ve also tryied to re flash the OS using the Toradex Easy Installer with no success because doesn’t recognize the USB dingle or the SD card with Easy Installer unzipped there.
Very strange but at the boot the system doesn’t recognize the SPACE pressure (probably for this reason I can not access to the boot menu and load the Toradex Installer).
So please i ask your support since I’m loosing to much precious time for a stupid action I made.
Thanks in advance
Giuseppe
