Today the toradex board has arrived,
i’ve connected the iMx6D to Ixora Board anc Ixora board to LCD and ethernet.
when i power up the board it show Easy Installer.
In Easy installer i’ve selected Windows.
The installer worked for a while then reboot.
After reboot the lcd screen show vertical colored line and the board remains dead.
I tried to reinstall Easy installer but get this error when i open recovery-windows.bat
g_dnl_register: failed!, error: -19
The error exit when i open “recovery-windows.bat” so the board is correctly connected to host pc i think.
When i power up board on consolle i see
Launching image at 10200000.
but nothing appen on lcd.
if i connect HDMI monitor it will remain in sleep mode.
What i was wrong in board initializzation?
How can i install WEC2013 image in imx6D board?
Thx for help
Solved recover problem, i have not removed JP2 before start board.
The Easy installer problem has remained, when i check wec 2013 it will install Wec but after reboot the board remain dead.
Ehat i was wrong?
Did you try to install something else?
My problem is that WinCe starts in VGA mode but my board (Ixora) have not vga output…
How can i change this setting if i can’t accesso to windows?
Dear @markdaan,
Sorry to hear that unpleasant experience of getting started with our boards.
There is a way to set HDMI display setting.
Use Remote Display to access the WinCE device on a desktop machine : https://developer.toradex.com/knowledge-base/remote-display#Remote_Display_V3_Over_Ethernet
Set or check below display registry setting, it will make cloning multiple displays, hence VGA and HDMI output will be the same.
https://developer.toradex.com/knowledge-base/display-driver-registry-settings#support-for-multiple-displays
Also, we have display tool to easily configure the different display interfaces.
Please let us know if it doesn’t help.
