IMX 8 Hard brick
Hi @alimert,
My colleague @alex.tx meant that, from the downloaded Toradex Easy Installer, you shall run the the recovery script on your PC to load the Toradex Easy Installer in the board.
The recovery script can be either “recovery-linux.sh” or “recovery-windows.bat”, that’s why the “-xxx”. Again, you shall run the script according in your PC, according to your operating system.
Please be aware of the necessary connections for a Recovery Mode on Apalis iMX8:
By the way, which Carrier board are you using? A custom or Toradex?
André Curvello
