i have toradex apalis module and carrier borad , i need ti install the Apalis_iMX6_LinuxImageV2.6_20160826.tar.bz2 , how i make it bootable in sd card ? Is their any tool
There’s loads of info in the Toradex developer website, depending on your needs. For example, if you definitely need that version of the image, you can try:
If you can live with a newer version, I find the Easy Installer very convenient:
i want to install the custom os which was built by my R&D team , how we can install that iso in toradex apalis module ? needs your help
